header logo
Go Back   Checkmate Community Boating Forums > Checkmate-Boats Marketplace > Engines and Components
Engines and Components This forum is for listing outboard motors, inboard motors, drives and all engine related parts for sale and wanted. For all other non engine related parts, such as guages, jackplates, steering and interior parts etc., please use The Parts Department forum.
Main Menu
Module Jump:
Google Search
Google
Latest Poll
July 2020's Boat of the Month Vote!
This poll is closed
I vote for "TuGHiLLBoYs" Convincor Shot! 0 0%
I vote for "Coop's" Starflite! 2 22%
I vote for "MsportRJ's" Pulsare 1850 2 22%
I vote for "jjg's" Pulsare 2400! 0 0%
I vote for "Jupiter Pulsare's" 2400 Pulsare! 3 33%
I vote for John Lamon doing some ice breaking! 2 22%
Voters: 9 100%
Notices
Reply
Thread Tools Display Modes
Old 09-07-2012, 04:40 PM   #1
demag67
Vice Admiral
demag67's Avatar
demag67 is a name known to alldemag67 is a name known to alldemag67 is a name known to alldemag67 is a name known to alldemag67 is a name known to alldemag67 is a name known to all
Model Owned: maxxum 281
Default mercury 2.4 200's what are they worth
i have a set of mercury 2.4 200 outboards. have dual stage reeds, velocity stacks, not original merc 260 cowls that need some body work and new paint, 2.0 gear ratio lowers that have bobs nose cones that need some body work where the original water intake ports are. have 1 piece heads. the one power head will need a new block though. everything internally is good just the block has a broken tap in the head bolt hole and one other hole is screwed up too. the other power head is good, and starts and runs fine. all the electronics are good on both motors. what do you think i could get for the pair of them? thanks
demag67 is offline   Reply With Quote
Old 09-07-2012, 04:43 PM   #2
demag67
Vice Admiral
demag67's Avatar
Default
their 20in motors
Old 09-07-2012, 04:57 PM   #3
illMATTic
Senator
illMATTic's Avatar
illMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud ofillMATTic has much to be proud of
Model Owned: '78 Predictor, '88 Starflite, '98 Convincor 220 (current)
Default
They sell anywhere from 2K to 3K each for a running motor.
Prolly get 1500 if you part the other one out as long as the crank and pistons are good. The used parts go like mad on S/F if they are nice. I have parted out many over the years.
__________________
Disclaimer... I may have zero first hand knowledge of the topic I am commenting on.
illMATTic is offline   Reply With Quote
Old 09-07-2012, 05:48 PM   #4
demag67
Vice Admiral
demag67's Avatar
Default
thanks, all the internals are good, just the block is screwed up from me.
Old 09-07-2012, 06:07 PM   #5
Ramifications
Ambassador
Ramifications's Avatar
Ramifications has a reputation beyond reputeRamifications has a reputation beyond repute
Model Owned: 1987 2800SX
Default
what's the new power going to be?
__________________
"You may delay, but time will not" - Ben Franklin
Ramifications is offline   Reply With Quote
Old 09-07-2012, 06:59 PM   #6
demag67
Vice Admiral
demag67's Avatar
Default
Not sure yet but probably 2 250 s definitely will be fuel injection
Old 09-08-2012, 08:38 AM   #7
illMATTic
Senator
illMATTic's Avatar
Default
Try to find some good running Opti's with low hours. The 3.0 EFI engines will use more fuel than those 2.4's. At least mine did.
__________________
Old 09-08-2012, 08:21 PM   #8
demag67
Vice Admiral
demag67's Avatar
Default
Found a set of 2002 250's that are efi but not opti's are they worse on fuel?
Old 09-08-2012, 08:27 PM   #9
SCT
Senator
SCT has a reputation beyond reputeSCT has a reputation beyond repute
SCT has a reputation beyond reputeSCT has a reputation beyond reputeSCT has a reputation beyond reputeSCT has a reputation beyond reputeSCT has a reputation beyond reputeSCT has a reputation beyond reputeSCT has a reputation beyond reputeSCT has a reputation beyond repute
Model Owned: 300 Convincor, 2100 BR, 2100 LD, V191, MX13, 13' Playmate
Default
Demag, I think a set of 250s will really wake your boat up!
Good luck-
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
demag67 (09-08-2012)
Old 09-08-2012, 08:35 PM   #10
demag67
Vice Admiral
demag67's Avatar
Default
Quote:
Good luck-
I am hoping so, I spoke to the original owner of the boat when i was down for rock the bay poker run. he originally had two johnson 225 ho motors with some work and boat ran 77mph on gps. if i could get that i would be happy.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard rebate boatn70 Play To Win!! 14 02-25-2012 10:31 PM
1991 Checkmate Starflite w/ 1998 Mercury 225 mjm351 Checkmate Listings 1 03-10-2010 11:05 PM
looking to know what its worth?? NOYZEE Play To Win!! 5 03-02-2010 10:07 AM
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright 2002-2020 Checkmate-Boats.com & Whitecap Enterprises Corp. All Rights Reserved.
Images & Content are Copyright material and may not used without prior written permission.
