header logo
Go Back   Checkmate Community Boating Forums > Checkmate Discussion Forums > Overhaulin' > Electrical, Audio & Rigging
Electrical, Audio & Rigging This forum is for Electrical, Audio and rigging related topics. Topics include wiring, gauges and fuel tanks, rub rails as well as audio installations. Topics related to engine electronics and wiring should be placed in the appropriate powerplant forum.
Main Menu
Module Jump:
Google Search
Google
Latest Poll
June 2019's Boat of the Month Vote!
This poll is closed
I vote for "PA-Checkmate's" Convincor! 5 33%
I vote for "senator-holland's" Convincor! 4 27%
I vote for "boatn70's" Pulse 210! 6 40%
Voters: 15 100%
Notices
Reply
Thread Tools Display Modes
Old 09-10-2012, 08:00 PM   #1
macho22
Wannabe
macho22 is on a distinguished road
Default Engine hatch electric actuator
1989 convincor engine hatch failed closed. Open wire from fuse to actuator. How do you open hatch with actuator failed closed? Need Help
macho22 is offline   Reply With Quote
Old 09-10-2012, 08:03 PM   #2
Kyain
Enchanter
Kyain will become famous soon enough
Model Owned: '89 25' Convincor GTX
Default
Quote:
is your rear seat still bolted in? If not you could possibly reach up and around the engine to get that center bolt out.
I assume you saying from fuse to actuator that you've already tested the switch and verified you are getting power to there?
Kyain is offline   Reply With Quote
Old 09-10-2012, 08:24 PM   #3
keith4216
Checkmate Guru
keith4216's Avatar
keith4216 has a reputation beyond reputekeith4216 has a reputation beyond reputekeith4216 has a reputation beyond reputekeith4216 has a reputation beyond repute
keith4216 has a reputation beyond reputekeith4216 has a reputation beyond reputekeith4216 has a reputation beyond reputekeith4216 has a reputation beyond reputekeith4216 has a reputation beyond reputekeith4216 has a reputation beyond repute
Model Owned: 91 Convincor gtx
Default
A handful had releases on them. I'm guessing if yours did you would know.
I'd try bypassing the switch and trying it hot wired touching the wires streight to the battery see if it opens. The switches go bad.
__________________
keith4216 is offline   Reply With Quote
Old 09-11-2012, 07:19 AM   #4
macho22
Wannabe
Default
Back seat bolted in. Originally put in new switch. Then jumped out the switch. I then checked the power wire and fuse. Jumped out the fuse portion. Checked wire with ohm meter found open wire No continuity. There are no quick pins on the actuator. I am really surprised at such a poor design. Very fustrated.
Old 09-11-2012, 10:57 AM   #5
ezstriper
Ambassador
ezstriper's Avatar
ezstriper is a splendid one to beholdezstriper is a splendid one to beholdezstriper is a splendid one to beholdezstriper is a splendid one to beholdezstriper is a splendid one to beholdezstriper is a splendid one to beholdezstriper is a splendid one to beholdezstriper is a splendid one to behold
Model Owned: 253 convincor(sold) 251 convincor(sold) 21 Eliminator Daytona 25 Sportcraft CC 50 Gibson
Default
get the bolts out of the hinges, may have to drill of cut them and lift from there, I use a quick release on the hatch side, but still would not be fun to get to...now my 251 I had a scoupe on it that made easy to reach thru..
__________________
"I have no recolection of that Senator"
ezstriper is offline   Reply With Quote
Old 09-23-2012, 09:32 PM   #6
BIGBREW
Playmate
BIGBREW's Avatar
BIGBREW will become famous soon enough
Default
I had this happen this year, before I knew there was a release pin to get the hatch open if the motor failed, I got pissed and lifted up on the motor hatch popping the plastic piece out of the steel ram.
__________________
BIGBREW
BIGBREW is offline   Reply With Quote
Old 09-24-2012, 02:15 AM   #7
keith4216
Checkmate Guru
keith4216's Avatar
Default
Did you get it open?
__________________
Old 09-24-2012, 02:20 AM   #8
macho22
Wannabe
Default
Quote:
I cut the hinges off with a high speed cutting wheel. lifted
the rear up and then unbolted piston.
The Following User Says Thank You to macho22 For This Useful Post:
keith4216 (09-24-2012)
Old 09-24-2012, 02:26 AM   #9
keith4216
Checkmate Guru
keith4216's Avatar
Default
Glad you got it open. Maybe use a pull pin when you put it back and bill Checkmate for your time. lol Someone wasnt thinking when they did that set up.
__________________
Old 09-25-2012, 12:36 AM   #10
macho22
Wannabe
Default
Where do you get a pull pin that size
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
32 Checkmates 4 Sale (3/15/03) @ www.boats.com Hot H2O eBay, Internet & 3rd Party Listings 4 07-28-2014 08:18 AM
"Wanted" Engine Hatch 72 Jetmate Jetmate The Parts Department 0 04-15-2009 04:54 PM
Loose engine hatch bracket Alex Electrical, Audio & Rigging 0 05-20-2006 11:56 PM
Electric engine hatch lift size? rsmit007 Engine Technical Discussion 6 08-22-2005 06:24 PM
Lots of Checkmates 4 sale (3/15/03) www.ablboats.com Hot H2O eBay, Internet & 3rd Party Listings 1 03-15-2003 09:27 AM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright 2002-2019 Checkmate-Boats.com & Whitecap Enterprises Corp. All Rights Reserved.
Images & Content are Copyright material and may not used without prior written permission.
