header logo
Go Back   Checkmate Community Boating Forums > Checkmate Discussion Forums > Props, Setups & Rigging
Props, Setups & Rigging This is our Checkmate setup forum. Topics include props, jackplates and setback, trim tabs, steering etc. This is also the forum to share your best setup tips and top speed numbers. So come on in and exchange setup details with your fellow members.
Main Menu
Module Jump:
Google Search
Google
Latest Poll
December 2020's Boat of the Month Vote!
I vote for "TuGHiLLBoYs" Convincor Shot!
I vote for "Coop's" Starflite!
I vote for "jjg's" Pulsare 2400!
I vote for "MsportRJ's" Pulsare 2100!
I vote for "Jupiter Pulsare's" 2800 with twin OB's!
Notices
Reply
Thread Tools Display Modes
Old 11-21-2020, 04:54 AM   #1
Check1382
Wannabe
Check1382 is on a distinguished road
Default My Checkmate predictor with tower of power 115 setup questions and gps number inside.
I have a Checkmate predictor with a 115 merc yesterday was the first time out the boat has tabs no jack plate 13/21 Michigan wheel xhs prop and motor mounted at the lowest hole. Everything went well and ran great Rpms where between 54-5600 depending how I had it trimmed with a gps of 55-57mph. The boat had a good amount of lift for the way itís setup but starts walking at wot when trimmed. Question I have is it worth putting a jackplate and trying different props If thereís anymore speed to be had and to get her more stable at high speed. The motor hit hard n gets right up on plane.
Check1382 is offline   Reply With Quote
Old 11-21-2020, 03:33 PM   #2
karzrus
Diplomat
karzrus's Avatar
karzrus has a brilliant future
karzrus has a brilliant futurekarzrus has a brilliant future
Model Owned: 08 Pulsare 2100br/250xs
Default
Quote:
Set back of the motor off the transom always helps these hulls with speed and reduced or more controlled chine-walk. The Predictor hull being 16ft probably needs a little less than the longer hulls. The other place where speed is found in these hulls when tuning is raising the motor so the centreline of the propshaft is even with the bottom of the hull or up to 1-2 inches higher than the bottom if the motor is fairly far back off the transom.
A jackplate will do both, I think you want 10-12 inches of setback to maximize speed and if you get a motorized jackplate you set the motor on it so that at the top of itís travel the prop centerline is just above the bottom of the boat, that way you drop the motor for holeshot and raise it as you speed up.
To save money a manual jackplate can be use, you just set it high for speed runs and sacrifice some hole shot, or set it in the middle for cruising or near the bottom for pulling skiers and tubes.
Depending on where the motor is set presently, you are likely to gain 6-10 mph. After adding setback and raising the motor you may find your prop is too small for maximum speed in the present set up, and gain some more speed with a prop change. You have to decide if that is worth the effort and money.
There are guys with 90mph Predictors, but they have ~200 hp and everything else right.
karzrus is offline   Reply With Quote
The Following User Says Thank You to karzrus For This Useful Post:
Check1382 (11-21-2020)
Old 11-21-2020, 07:00 PM   #3
Check1382
Wannabe
Default
Wow great info thanks for taking your time to explain things.
Old 11-21-2020, 07:01 PM   #4
Check1382
Wannabe
Default
One quick question do you mount the jackplate right over the factory plate? Also do you feel it needs as much setback as ten? I was thinking 6
Old 11-21-2020, 09:29 PM   #5
karzrus
Diplomat
karzrus's Avatar
Default
Not sure what you are calling a factory plate, you need ten posts here and a hosting site to post a picture, but it would help to see what you are talking about. Maybe you have a metal plate spreading the load of the motor over a large area of the transom, hopefully the transom is solid as they often have issues when old that do not mix well with higher speeds.
Anyway if this is what you are talking about then it should be able to be left in place and the jackplate/setback bracket can be added.
6" of set back will help with speed and likely raise the speed at which chinewalk starts by a few MPH, if you are trying to keep the boat good at watersports you may want to stop there. But maximum speed out of the hull will likely need more than 6". your call.
Old 11-21-2020, 09:54 PM   #6
Check1382
Wannabe
Default
Yes the plate I speak of is the factory plate on the transom the motors bolted to. I’m going to grab a jackplate and start there. I’m thinking of getting a laser2 prop maybe 23p what would you suggest? Thanks
Old 11-22-2020, 07:57 PM   #7
karzrus
Diplomat
karzrus's Avatar
Default
Try the jackplate with the prop you have first.
If you do a search here on this forum, you should find the set ups of other Predictors to get an idea of where you want to be with setback, and prop.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright © 2002-2020 Checkmate-Boats.com & Whitecap Enterprises Corp. All Rights Reserved.
Images & Content are © Copyright material and may not used without prior written permission.
