1983 Diplomat Restoration Project
ScottyP
I purchased a 1983 Checkmate Diplomat at an estate auction for $881.
I was able to get the engine fired up and looking forward to this boat seeing the water again.
One small soft spot in the floor ended up being a partial balsa core repair and a complete stringer and floor removal repair.
I am doing my first restoration project and this thread is to share my progress.
Any tips or suggestions is greatly appreciated!
Unfortunately this is what I found when I started to uncover the “small soft spot”. It turns out the motor mount stringer was rotten all the way through, so the motor had to come out.
The area that had the floor opening was all rotten to the balsa. This was not fun at all!
I used lattice and hot glue to mock up the existing box seats and I used cardboard and hot glue to mock up the new floor piece.
This past weekend I built the stringers and the rear motor mount. Hopefully this weekend I will be able to start glassing.
Needed some parts for the 470 so I picked up a donor boat this weekend. Same motor and I plan on using the trailer and the outdrive towards the checkmate.
