Turbot-bird
Anyone have any pictures of there engine bay with a 350 in it? I have to rebuild my mounts for the 470 and while im there I want to put some in for a 350 if I decide to switch later in the Diplomat.
Whats a 470
I did not know I am not to up to date on 4 bangers but it did sound like a big block. I thought it was a new stroke kit for a 454A 4-banger
V8 uses side mounts and requires you to build stringers to set the motor on
We took out the flotation boxes and built stringers out from transom
What are you going to use for exhaust? thru-hull?I can send you some of the 4.3 in mine (88 model) if you like... it's getting a 383 next week or so once I get the last couple pieces of the exhaust set-up together and make sure i have everything else lined up so I dont have to stay off the wayer for too long.
the v-8 with iron manifolds int&exh is only 100lbs heavier than the v6 so alum int & exh should actually be lighter
what engine spec's on 383?
