....i spoke with a guy the other day that said use regular staples and cover them with silicone. That way they still rust a little and the rust prevents the staple from backing out of the wood. .... Comments or opinions??
Not that I know much about doing upholstry, but I don't buy that. For one thing everybody that has experience doing upholstry says to use stainless staples, if there were a better solution it seems like these people would have found it over the course of their many years of experience.
There's not a bunch of force on those staples acting to pull them out (that would be a force straight out of the wood). Most all the force applied is perpindicular to that direction, caused by the pull of the vinyl fabric, to me this sounds like a non-issue.
Silicone emits acetic acid as it cures, that's going to hasten the corrosion process on any metal (once upon a time I knew a young engineer who thought it would be a good idea to seal up some data cable connectors with silicone - less than a year later thay all failed because the copper wire had corroded).
I'm building new captains chairs. Bottom is 3/4 ply and the curved back is 2 layers of 3/8. How were the originally constructed? Mine were missing so I have no pattern to go by. Just made up my own.
Just curious as to how the seats turned out? Do you have any pictures?
