gangnamstyle
Hello, I’m new here and looking for some prop advice. I have a 1986 Exciter I/O, Merc 260, Alpha drive.
The prop that came on it is a stainless three blade 23 pitch. It seems to be to high a pitch under a lot of conditions, works well at high speeds of course but very slow off the line or if you’re cornering etc. I can get about 60mph out of it if the boat is light.
Last season I bought an aluminum 21 pitch, and we successfully ski behind the boat, it’s much better off the line but obviously loose on top end speed. However, there seems to be cavitation, even just in cruising along. Sometimes the RPM’s change and you feel a “surge” or a slow down. I’m assuming this is due to it being an aluminum prop?
My tach is a bit intermittent, and I’m planning on having that replaced before this next season so I can post RPM’s. (It’s electronic and water makes it erratic.)
My question is: would a 22 pitch prop be a better setup for me, and how important is stainless vs aluminum? How about a 4 blade prop, and what pitch in that case?
Thanks in advance for the help!
Sam
Sam
