Hey everyone I've got a 24' Enforcer. With the original 330hp engine I was able GPS the boat at 63mph with a 24p 4blade.
I wanted to leave this engine completely whole and build a new engine and pick up speed, in the end this worked to my benefit...
I picked up a 427 on the (very) cheap. I know... no replacement for displacement, but this is what and I had didn't feel it would be hard to build 450hp with this setup. I re-used this original Mercruiser 325hp short block as it looked clean.
So, I picked up a set of oval port ProComp.. head castings from my very reputable machine show who did the machine work and had them put quality stainless valves in them. These heads are 115cc chamber and my factory 427 pistons are popup, what I believe to be 11cc. I'm running Edelbrock Air Gap oval port intake. And my cam is from Schneider cams "JB-3H" .540 lift and at .050 duration intake 224 and exhaust 230. We set the timing all the way up to 39 deg, trying several different settings from 34-39. At the time of putting the motor in my boat I also added stainless marine performance exhaust manifolds.
After I broke the cam in on the outer springs. I used a leakdown tester to prevent the valves from falling down when inserting the inner and didn't notice anything out of the ordinary. (didn't take actual readings)
When I ran the boat for the first time, after getting all the carb jetting good, I couldn't get the boat to turn more than 4200rpm with the same prop GPS at only 57mph. I'm running pretty large carb 950, I've tried another carb, a 650 and slowed down. At one point I had dropped 400rpm and couldn't get it back to where I was. (collapsed lifter)
I did a compression test and had 125psi on all but one cylinder, it had 25psi. So, I pulled the engine and did leakdown tests on all. Most were 10-15%, there was one that was 25%, 28%, and the one with low compression was BAD. The piston with low compression (#5) had a collapsed exhaust lifter.
I pulled #5 piston and couldn't see anything wrong with the piston, rings, or head/valves. The whole engine looks very clean and there is actually very little cylinder wall wear.
I ended up putting my original engine back into the boat and regained my 63mph speed at about 4700 or 4800.rpm
So leading up to my question:
What is the true cause of my lack of power? Would it be worth my efforts to hone and replace piston rings? I would hate to go through the efforts of all of this and end up with the similar results.
Should I ditch the 427 and build a 489 over the winter? (I know the answer to this, but please be in mind that I would like to spend as little as possible, just like everyone else)
Thank You if you actually read all of this...
