I've read other's questions regarding seat rebuilding and think this might be something I can take on. The plywood in the back portion of the bench seat is begining to rot around the edges. Is there more to this than unstapling the cover, cutting new plywood, and restapling the cover and foam to the new? I wonder if there are some attachments to the plywood that aren't exposed to help form the seat cover. I usually dive into these things without thinking and then regreat it. Also, I have priced A/C plywood and Marine grade, quite a difference. Will a standard plywood be durable enough if I coat it with fiberglass resin or something similar?
Thanks in advance for any advice you have
