jumbofordman
So I spun the hub in my old Mirage prop (no PVS.) When I pressed the old hub out, I noticed the square pattern the rubber hub was pressed into looked a lot like the Flo Torq hub pattern. So I happen to have a flo torq II hub insert laying around, I dropped it into the prop and it fit perfectly.
So the question is - do I need to bother having a new rubber hub pressed in, or can I just use the Flo-Torq hub?
