Prop work advice needed.
PA-Checkmate
With winter I need advice on who and which prop I should have worked. B1 24p vs QIV-X 24p. Both are 4bld. 2002 Convincor 496HO with normal load, usually 1/2 tank gas or more runs 65, but when the stars and moon align then just over 67. GPS. The only difference I notice is when under about 40mph the Hydromotive needs more tab down to control porpoise.
Pretty sure Bblades has a winter special. What are you looking at getting done?
Just to get a little more out of it? Not sure if lab would add any MPH or not. I think BBlades said need to remove bow lift since it's not needed for the convincor 270.
After communicating with BBlades he feels B1 should produce better results vs Hydromotive. Spring here yet? Will update then...
