DaMan186
Early this spring I was crawling around under the boat doing a preseason check and found 3 spots with gel coat completely gone must have hit something and never knew it. I decided to fix it myself. picked boat off trailer with forklifts. Filled spots and sanded smooth then sprayed gel coat on the repair. In the process found a prior repair made. That was never told about, i found out a couple weeks ago what happened. Wet sanded the areas what were sprayed and then buffed the entire hull and waxed. Just buffing the hull really added a lot to the boat.
