Sam I am
Okay...I know there is misinformation out there regarding reflashing the Verados, so let's see if we can set the record as straight as we can for everyone who might be considering this.
I am considering getting a boat with a 200 Pro Verado on the back. I've talked to a lot of folks and researched many, many boards about reflashing the 200 up to a 300 at Eric Simon's shop. To my knowledge, the 2 motors are identical bolt for bolt above the gear case, except the ECU. The gear cases only differ in ratio as the 300 is a 1.75:1 and the 200 is a 1.84:1.
Every once and in while a new factoid will pop up that I haven't encountered before so I'll do my best to verify if I can. So, with that in mind, the most recent one I encountered was that the pistons in the 200 are not the same as the 300. However, I don't think that's correct but I'm not certain either. I've looked up pistons for each motor and the part numbers are coming back identical. However, what I don't know is if the pistons corresponding to this part numbers are somehow different from OEM pistons.
200 Pro Piston Part Numbers: https://www.perfprotech.com/mercury...connecting-rods/assembly/16769/150?model=1427
300 Pro Piston Part Numbers: https://www.perfprotech.com/mercury...connecting-rods/assembly/16769/150?model=1429
Jupiter Pulsare raised another one with a windage tray for oil. I have to confess I don't know what that is. I'm hoping he can help me understand and have asked him to jump in here.
The other thing I'm not sure about is that there are differences in same model engines from older engines to new engines after a certain serial number, but I don't know what changed in the engine to cause them to differentiate at the designated serial number.
I'll ask John Lamon to jump in here too as he's a Mercury tech.
