2 questions, what is needed to swap a sbc to BBC and will this cam be a good cam
crazygn
I trashed my 350 last year and just picked up a 454 to swap. What's needed to do this, will the mount need to move or bolt up and what about the flywheel is it the same one on my 350. The 454 I have cam with this cam will it work for a marine cam.
The cam is by a custom cam grinder
Camcraft cams in N/carolina
#51-2530-10A4-HCR
Advertised duration 276/288
.050 226/230
Cam lift 314/320
Valve lift 534/544
Zero valve lash
Centerline 106/114
Lobe seperation 110
Valve timing At .050
In.open 7BTDC In. close 39 ABDC
Ex. open 48 BBDC In. Close 2 ATDC
I'm no marine V8 expert, but in cars the only change needed is exhaust manifolds. They take the same engine mounts and the same flywheel.
Definitely different flywheel. 350 is internally balanced, 454 is external so it has weights on the flywheel.
