CheckmateFever
My summer has been a bust so far. In the spring the shop that takes care of my boat put a brand new SEI Alpha on the back of my boat. I picked it up, couple weeks before Memorial Day weekend, got to the lake and it fired right up with no problem. Idled fine, went into gear smooth, backed it off the trailer and idled out. When i tried to advance the throttle from idle (in gear) it died instantly. No cough or sputter, just like i turned off the key! That's all it would do, so i dragged it back to the shop. Three weeks later, now after Memorial Day, they call and say "it's running great, no more problems". Supposedly clogged fuel filter, also cleaned out the carb, and did a full tune up (to the tune of $400). Get back to the lake, the boat does the exact same thing, idled in gear fine, quits just barely touching the throttle forward.
Took it back to the shop, mechanic is stunned, now after a couple more weeks diagnosed it as a worn out throttle cable causing it to trip the shift interrupt switch. So in goes a new throttle cable (and more $$$ too). Get back to the boat launch, guess what, still quits when advancing the throttle in gear!! Are you kidding me??
Back to the shop, this time we put it in at their launch, he makes a few adjustments, and we take it out for a test run. Now, it would start to come up on plane, somewhat laboring, then quit just before getting on plane.
Well at least that was an improvement. Does a couple more adjustments, still same deal.
Leave it again, talked to him 2 weeks ago, said he's had it out several times and is pulling his hair out, never seen one act up like this. Ran every diagnostic test there is, everything is checking out good. Rebuilt the carb, gone thru all the ignition, so far hasn't figured it out. It revs and sounds perfectly fine while in neutral! Any idea's i can relay to the mechanic? They've been a good shop for many years, maybe not so much now all of the sudden, i don't know. Clocks ticking away on boating season, the frustration ship set sail along time ago!!
