ynnad
I have been trying to get my 7.4MPI to start after about a year storage in Florida.
I filled it and treated the fuel (ran it to get it all the way through the system) before I stored it. It was running fine when I put it away.
When I first tried to start it, it wouldn't crank. Turned out to be corroded ground at the engine. (sits on a hoist, but we have salty to brackish water that seems to cause everything to corrode).
After I cleaned the ground it cranked, but no fire. I had the fuel tank pumped dry, put in fresh fuel and a new filter. Again no start, not even a pop.
I pulled the plugs and found them from black and sooty to some with rust!
I pulled the distributor cap and found all the terminals had white corrosion as did the rotor.
New plugs, cap and rotor...now it fires (pops) on the 1,3,5,7 bank but not on the 2,4,6,8 bank..It turns like it wants to start, but it will not catch and run.
I have never had this problem before even when it was stored without treating the fuel...I do have fuel in the system. I checked at the schrader valve on the fuel rail and it squirts fuel.
I am not sharp on the MPI system, so I don't know if I have stuck or plugged injectors...it does seem odd that only one bank will fire.
Any experience on this?
Thanks in advance,
Dan
Thanks in advance,
Dan
