Dashboard repair?
JKG8R
I just bought my boat and want to fix a few things, one being a broken section on the dash beside the steering wheel. The previous owner did a really nice job of repairing a couple of places with something like white vinyl tape. Since I don't have any tape to stick over it I'd like ot fix it correctly. I have fiberglass and I've worked with it before but should I use that or something like Marine-Tex to fill this in and sand it smooth? The boat looks good but it appears to have been clear-coated so I plan to remove the gauges, steering, throttle, etc... and prime, paint and clear that whole area and make it shine again. I also bought a new switch panel so I'm going to fill in the hole from the OEM cluster and cut the hole for my new switches. Any insight is greatly appreciated.
My dash repair was/is part of a larger project, but here is how I approached it. I decided I only wanted the speedo hole and two small holes for toggle switches to remain. The steering had been butchered with too many applications. When I had the deck off I cut out and replaced the wood with holes in it. I glassed in new wood on the back side. Then I flipped it, Glassed in the face and finished with bondo. A lot of work, but strong and will hopefully hold up well. Here are some picks.
picture.php
picture.php
picture.php
That's a really good idea. I hadn't thought of cutting out a larger section and just glassing in a new section. That would make a much better repair in the long run and shouldn't take a lot more work to complete. That will also give me a lot more flexibility with how I position my new switches. Thanks for the input!
