Difference between Bravo 1 and Intimidator Quad IV / Intimidator Quad
Hi!
I have been reccommended to try a Bravo 1 prop for my Phantom 25 offshore hull with a PM 300 SVS. The boat runs 77-78 mph spinning a blueprinted A45 Tempest 25 and 45 Tempest 25 at 6.100 / 6.300 rpms. The hull weight is approx. 1.150 kilos / 2.500 lbs incl. engine and driver.
It is very difficult to borrow props for testing in Norway, but I can get hold of a pair of Intimidator Quad IV and Intimidator Quad IV-X's props. They should have the same caracteristics as Bravo 1 prop.
Do you have any experience with those two / three props and any difference between them. I am looking for max top speed.
Cheeers,
Toffen - Norway
Hi!
Cheeers,
Toffen - Norway
Toffen, I tried all three on my zt230. The Q-IV is more of a stern-lifting prop and the Q-IV-X more of a bow-lifting prop. On my application, the Q-IV made the boat feel glued to the water and I lost almost 5 mph over the Bravo One. The Q-IV-X performed alot better, but was still off by almost 2 mph over the Bravo One. So, in the end, I'm sticking with the Bravo One, especially since you can lab them, and get a bit more performance, whereas I don't think you'd want to lab the Hydros because the blades are already pretty thin. I guess you won't know unless you try them out, but it can be pretty expensive with all the shipping fees - especially given where you're located!
