1.5 is always the best way to go. People will change the gear in the drive when their speeds exceeded a prop selection thats offered. Most common change is going from a 1.5 to a 1.36. The speed for a I/O would be over 90 before you would consider a gear change
...when propped right turning a higher pitch prop slower will yield a higher top speed all other things being equal.
It's a combination of the angle of attack / pressure differential across the blades and the fact that the higher pitch prop has to move less water to go the same distance and so is more efficient at translating torque into forward motion....
I believe the increase in efficiency for a higher pitched prop is mostly that there's less parasitic drag because it's turning slower (for a given speed). Also, to go a certain speed you need to move the same amount of water no matter the pitch (up to the point that the prop is "blowing out", as you said). It's that Newton's Law thing - for every action there's an opposite and equal reaction blah blah blah.
Good discussion.![]()
Man you guys are really working your brains. I love rocket science.
or just to basicThats what I am thinking maybe my post is invisable to themor just to basic
The boat would probably be faster with a 1.6 ratio depending on how fast already going...
What do you expect from a scientist...![]()
To be honest most BB engine builds I have seen lately really suck. People still dont get it, your torque numbers on the dyno must be higher to have a good strong boat. HP counts but not near as much as torque
Hear that. Although horsepower is what determines max speed and so if trying to get the highest top end out of something we put gear and prop to have wot and peak horsepower, without strong torque numbers across the rpm range even a little boat will be a dog.
