Genuine Mercury Engines
mkhammer
There was a lot of cracked blocks this winter with the cold snap across the nation.
Mercury is producing all size replacements and they will not last. Replacement engines will run out of stock, Then there will be a waiting line to get the engine you need.
So if you need a factory replacement engine I am giving the heads up. now is the time to buy.
Free shipping to all lower 48. No core charge on many and the engines that require a core charge it is refundable, There is a crate return charge that is refundable when the crate is returned. The prices are the best you can get right now on these factory engines that come with a 1 to 3 year Mercury wartranty. The quality is second to none, Buy with confidence from the industry leader that will stand behind their engines.
3.0 $2795.00 Long Block no core
4.3 vortec $2590.00 long Block/ no core.
5.0 $ 2575.00 Long Block/no core
5.7 $2575.00 2- piece rear main/ mechanical fuel pump/Long Block/ no core
5.7 $2675.00 Roller lifters 92 to 97 Long Block No core
5.7 $2800.00 Vortec Carb /TBI non MPI long Block 96 & up.
383 MAG STROKER/ENGINE ONLY/350HP BRAVO STERNDRIVE APPLICATIONS. 350-HP 383 CUBIC INCH STROKER GEN + MPI FULLY DRESSED MARINE ENGINE ASSEMBLY. FEATURES INCLUDE A MULTI-PORT FUEL DELIVERY SYSTEM WITH COOL-FUEL DRY JOINT EXHAUST STAINLESS STEEL VALVES THUNDERBOLT V IGNITION HOSES BELTS ALTERNATOR STARTER-MOTOR FLYWHEEL HOUSING ETC. RUNS ON 87 OCTANE FUEL. READY TO DROP-IN FUEL-UP AND START. $10,035,00
7.4 L29 98 & up roller lifter $4665.00 Core charge required call.
7.4 flat tappet $4395.00. core charge required call
8.2 502 roller lifter carb or MPI replacement $6,065.00 Rectangle port.
I have 380 and 425 HP 496 8.1
and the new 380 and 430 HP 502.
I have Bobtails, ready to run engines and custom engines, Don't see what you need co0ntact me. Forum members will get their discount.
