"Help" Brovo 1 HP Hinge Pin
jordan705
I'm in need of some assistance on removing this hinge pin. Cant seem to figure it out or find any info on it so any help would be appreciated. Thanks
My boat has those too. If I remember, you screw a bolt in the center hole and use a slide hammer to pull them out after removing the 2 screws holding them in. Autozone rents slide hammers for free. You just have to leave a deposit which they give back upon return of the tool.
Thanks for the input. I will have to give it a try and see what happens. Did you just tap them back into place when finished?
Make sure the fiber bushings are still good. I replaced mine. The hinge pins simply push in, if they are a little tight, some liquid soap will help.
You are going to need one of those too! Seller may have not used a hose to start it when showing it for prospective buyers.
