Prop Selection - 1997 Checkmate 253 Convincer
Cory
Hi - first I would just like to thank you for providing such a wonderful site. I haven't been a Checkmate owner for long but I have already learned a lot here.
I have a 1997 Checkmate 253 Convincer with a 454 Magnum and a Bravo One Drive. The motor is Carborated and I'm not sure of the horses.
My question - do you know of the right prop/pitch, etc. for my boat? Also, does anyone know the horsepower of my 454 Magnum and what speeds I can expect with the right prop?
First day with the new boat.
Thank you very much
Cory
Newport Yacht Club
Lake Ontario.
Thank you very much
Cory
Newport Yacht Club
Lake Ontario.
Welcome aboard Cory!
Thanks for the nice words about the site.
Webmaster
I believe your 454 puts out about 350hp with an operating range between 4600-5000 RPMs.I would think a 23 Mirage 3 blade or one of the Bravo 4 blade props would work for you.One of the members here (Vinny) has a similar boat and could give you his 2 cents also.
87 ENFORCER CUSTOM EDITION,454 MAGNUM SS ALPHA W/CUPPED 22 PROTESTOR PROP
Hello Cory and welcome,
I am not certain of the horsepower rating on a carbed 454 Magnum. I know the MPI motors from that year and newer are rated at 385 hp. I would imagine that the carbed motors are a little bit less. As far as props, what are you running now? What rpm's are you seeing? I have a basically stock 454 Magnum MPI, I am running a labbed 26 Bravo 1. I can turn it to 4950 rpm. If you wanted to run a box stock prop, I would have to say that either a 22 or 24 Bravo 1 4 blade would work for your motor. Personnaly, I prefer 4 blade props, you can't beat the additional mid-range you get with a 4 blade over a 3 blade.
I forgot to mention.
To date my engine mods only consist of Gil Offshore exhaust, Vortech flame arrestor and adjustable fuel pressure regulator, MSD 6M-2. Next winter I plan on a Whipple Charger.
I swing a 23 Mirage 3 blade at 4900r's with a 330hp 454 in my '90 GTX 251. There has been a few mod's, cam, intake, Exhaust, and some head work. Est. hp. would be near 400. Would like to try a 4 blade
MikeW
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by MikeW:
MikeW<HR></BLOCKQUOTE>how fast
MikeW<HR></BLOCKQUOTE>Hey Mike, I was trying to email you but the addy I have is outdated. Can you contact me? I wanted to get an avatar loaded for you. Thanks!
Webmaster
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Cory:
http://home.cogeco.ca/~darh4/checkmate.jpg
Thank you very much
Cory
Newport Yacht Club
Lake Ontario.<HR></BLOCKQUOTE>
You can expect upper 60's for speed. your motor makes 365HP and should be propped at 23-25 pitch. If you have some speed info (GPS) for a current prop and rpm we can help you better. I would try a 25 Mirage plus or a 24 bravo and go from there. It's easier to go down in pitch than over rev the motor. If you try a 23 be careful not to exceed 5000rpm.
Scotty, I need more power!
cory.
I own a 96 253 convincer with a 454 mag mpi. when it was stock I ran a 24 pitch hydromotive quad 4. I run in very confused water and the 4 blade handeled much better than the 3 blades. I had run 67 mph with it, on gps. None of the 3 blades were any faster, and they didn't have as high a cruise speed. My guess is you might try a 23 q-4. by the way your motor was rated @ 350 HP in 97, the exact motor was rated @365 hp a couple of years earlyer, same engine differnt way of ratting them.
