Replacing steering wheel seal on a Sea Star helm
jmahler
Has anyone replaced the front seal behind the steering wheel on a hydraulic helm? I have a late model Sea Star helm and there is fluid coming out of the front seal. I ordered the seals from Sea Star and they said it was easy to do on there web site. I got three (only 1.50 each) just in case I mess it up. Thank you! Also how do you bleed the system after replacing the seal?
Thanks to Merc-Mate for shooting me an email on how to blead the system.
Now has anyone replaced the seal on the helm?
acutally it is pretty easy.. pop the center cover out of the wheel, then you'll see a nut.. take that out, and configure a puller to assist in pulling the wheel off.. (sometimes they pull off easy).. you'll then see the seal.. after replacing the seal..bleed the system..
Shop notebook: This maybe a temporary fix.. and may begin to leak in a couple of weeks.. if this should happen.. bite the bullet and buy a new helm assembly. Alot of times there is slop in the helm assembly.. and it will not seal..
