I'm running a GM marine 350 in my Entertainer I/O. It's a 1980, with the original outdrive. My temperature gauge has a midpoint of 150 degrees, and a maximum reading of 240. At cruising speeds I stay just over 150, but if I hammer down on it, or if I putt along at idle speed, it climbs to around 200. Is this normal? What is the optimal operating temperature?
Secondly, I have an oil leak somewhere, and could use some advice for tracing the source. It's dripping off of the oil pan by the drain plug, but it's not coming from the plug itself. I've tightned down most of the oil plan bolts, and they were loose, but it is still slowly dripping. Over the course of a month about 3/4 of a quart dripped out, so it's very slow, and it certainly doesn't seem to be hurting anything other than to annoy me knowing it's there. It wasn't leaking before this year, and I put the engine in around 1996. I used it for a season and a half, and it's been sitting untouched until this year. The engine has less than 70 or 80 hours on it, so it worries me that it started dripping seemingly out of the blue. It didn't seem to leak until I changed the oil a couple of months ago. Anyone have any ideas?
