thru hull to captains call conversion
the how part.. pull the drive and engine to install the y pipe time wise should be less than 8 hrs.. after that its a cake walk.. some hose cutting and slide in the captains call // silent choice... and install the risers.. (about 1.5 hrs) you'll need to pull some wires from the dash and install a switch at the dash.. wiring can be short and sweet.. or if done correctly may take a couple of hours.. use the good shrink tube fittings..
the cost of the units vary from manufacturer.. be sure if you purchase on line that they will work on your merc... some of the cheaper versions have a 4" round pipe instead of the oval you'll need to go into the y pipe..
