hotbeek
I'm still working on break in but decided to throw on my Bravo 28. My Bravo has one set of 3/4" holes. This prop could definitely use 2 sets of holes. The prop had some bog out of the hole but once it spooled up it pulled like a freight train. Prop had excellent mid and top end accelleration. I was running level with pad and neutral trim. I spun this prop to 6000 rpms. I think with an extra set of holes this prop could be a real killer. With a few more hours I plan on running this prop to it's potential. I think running it up to 1 1/2"- 1 3/4" above pad will net some great gains. I suspect this prop will spin over 6200 rpms at those settings. I have a 30 Bravo that's waiting for some pvs holes. I think the 30 should spin in the 5900-6000 rpms. at 1 1/2"- 1 3/4" With a little work to prop it should then turn 6150-6200 rpms ?! Which I hope will be 92-93 mph GPS. Only time will tell ???!!!
