Tx91z28
It a been a lot of work but it's turning out better than I expected!
Ok got my pictures back here are the carbs all apart:
Jets soaking in acetone:
The carb body and bowls are warped about .015" total in The worst spots:
Light sand on a flat machined plate with 400 grit sand paper cleaned the bowls up quick:
The carb bodies were a bit worse, but two hours later they are pretty dang close to perfectly flat:
Im going to run the carbs through a soap/water bath and reassemble them tomorrow I hope
