I have a 1600br with a factory mounted 115 Optimax. I have a total of 28 hours, and a water pump failure. The mechanic says the outboard is mounted too high. It came mounted in the second hole (from the top) in the mounting plate at the top transom hole. The mechanic says it needs to go down at least an inch.
Furthermore, it came from the factory with analog gauges that include a temp and water pressure gauge. Both are hooked up, but the temp gauge does not work. Mercury says it is impossible to hook an analog temp gauge up to that outboard (although checkmate installed them), and that's the reason it does not work.
I'm in Portland Or...a long ways away from Ohio.
Any suggestions with regards to how high the Optimax should be mounted, and comments about the water pump and gauges?
The prop that came with it is a stainless stiletto three blade prop.
The mechanic is scheduled to lower the outboard on Tuesday.
I intend to call Checkmate on Monday, but they haven't been very helpful so far.
