to replace to old metal one at I bought my tank todayto replace to old metal one at
http://store.easternmarineoutlet.co...atalog.prodInfo&productID=8700&categoryID=483
It was the cheapest that I could find anywhere at $164 with shipping.
26" x 16" x 11.75" - 19 gallon fuel tank = 18 gallons fuel:1.5 quart/3 pints oil for a 50:1 mixture.
what kind was your old tank? I need a metal one. I got the crappy one from gander mountain right now.
It's yours if you want itYeah I'd be intrested. Do you have time this weekend?
Nice work and Nice PicsUsed poly resin...I do not like working with it compared to epoxy but had to try it.
I was told that epoxy will stick to anything but poly won't stick to epoxy. Were you told the same thing when purchasing your materials? It looks like your jack plate should cover up the "lil " places where you sanded through, if not no biggie!
hey do you by chance have a compression tester? I want to make sure my mercury is running good. also, any plans this weekend?
The motor is most likely going to be a fall/winter project. Trying to get as much glassing done while the weather permits outdoor sanding.
