slingblade
we have got the parts from the machine shop and they look great.
We had to do some measuring for Bob and found a problem in the valve train.
when you add lift on a cam ,the lift does not only come from exrta heigth on the lobe but from a smaller base line circle.This makes your lifter ride lower in the bore when the lobe is down.. The cam that was used should have had a virtical bar instead of the dog bone style lifter that is used in this motor. We were going to have to use a smaller cam profile to use the lifters. But after a close inspection the lifter has been rideing out of its retainer and has worn machined spot for the retainer seat.
some fuzzy pics sorry
I can't beleive it stayed in there . The good news is It will get the right lifters and cam . And we can go back to what we want. I am copying a build that bob has done before with this combo. Should make 620 HP @ 6200 with pump gas N/A. I think that it will be pleanty of HP for that light boat.
and shake the windows on the house boats at the dock .
