Hello. I'm Steve Smith, and I invented Clear Penetrating Epoxy Sealer (also known as CPES) back in 1972. It has come to be used for quite a variety of things, and in some cases I feel it is being used where its best performance is not attained. I want my products to always give the best possible results, and so sometimes I get involved in forums where applications are being discussed. Let me state a few basic principles about the product.
It does not make water vanish from a confined, waterlogged space. Nothing does. The physical process of evaporation must take place somehow.
Clear Penetrating Epoxy Sealer contains solvents, which must be allowed to evaporate from the wood, in order to give good results in the restoration of slightly deteriorated wood. When the solvents have evaporated, the restored wood has a similar porosity to natural wood, so the wood can "breathe". I designed it that way. That's important, particularly at the interface between the sound wood and the slightly deteriorated, now restored, wood.
There must be empty space inside the wood, for Clear Penetrating Epoxy Sealer
or anything to be able to soak in. That means the moisture content of the wood needs to be below the fiber-saturation point of wood, typically about 30% by weight moisture content.
There is not a good way to measure this, inside a fiberglass skin. The moisture-meters with pins measure the salt content of the wood, not exactly its real moisture content. The correct way to measure moisture content of wood is the way the Stud-Finders work: they use radio waves, not metal pins that poke the wood. The best one I know of is the Wagner L606, made by Wagner Electronics in Rogue River Oregon. You can find them easily on the Internet.
There are two ways I know of to get the mositure out of wood. One is to drill many holes and let the boat sit for many weeks in hot weather. The other is to drill some holes and vacuum-dry the wood, and so I wrote an application note about that. Anyone who wishes to receive one can go to the company website
www.smithandcompany.org, get the general inquiry email link, and request the vacuum-drying application note.
Missing physical space can afterwards of course be filled with various liquid epoxy fillers.
Steve Smith
