Best Manual Jackplate
Ok, Ok, I was mistaken, Darn it. I thought he was looking for a J/P for his Enticer. Jallen you were right.:shakehead:
I thought about adding a jackplate to the Enticer, but if I was serious I'd need dual cable steering, new prop AND a jackplate, and that'd probably only get me +5mph. So then I'm looking at a new engine. That's why I've been looking around at slightly larger boats. I love the Enticer, it's in incredible ORIGINAL shape and very fun, but it makes more monetary sense to look for something else and try to sell the Enticer.
So basically I'm looking for the lightest, strongest, (cheapest), 10" setback plate with a single screw from-the-boat adjustment. That can't be too hard to find, right?? :brickwall:
Too bad setback isn't adjustable as well, I'm basically taking an educated guess based on the experience of Mark and jallen toward the 10".
Not too many single screw types. Most have 4 bolts to loosen and then a single screw. Detwiler makes the true single screw. Rapidjack is pretty cool with the ratchet adjustment up and down. They are all light and strong except for the Gorilla Jack which is strong, heavy and strong.
i have a cmc 12" on my starflite and will say this-
THE CMC STARTS WAY HIGHER THAN ANY OTHER JACKPLATE!!!!!
i don't care what anyone says this plate/setback is by far the highest starting jackplate i have found! when i say this i am talking about from where the motor was mounted to where it is after installed. do some research and you will find out that the CMC is actually about 1.5" inches above(at the lowest point)any other jackplate you will find.....
i know i will get a response out of this one:popcorn:
-ross-
They wont work on a starflite thats a fact.
I have a 6" CMC manual jack plate on a 1979 Entertainer and it made world of difference in the boat performance.
jackplate size
pm Randy (Wildman) on here, he is a dealer and has had alot of experience on the right setup for each model.I would buy a 1/2" plate thickness model that will take up to 300hp whatever you end up buying. I have a TH marine pro hijacker I like, the Bob's convertable is also a good unit.
Steve
What are you saying the 10" setback- jackplate won't work on a starflight hull? I haver an Enchanter ( almost the same hull except for the pad instead of the full V )? Randy told me to set my new 10" CMC up with a 200 2.4 black max at @ 3.5" below the pad......When I hear people saying a CMC 10" WON'T WORK ON A STARFLIGHT, it makes me wonder why?
I believe this was in reference to a CMC not working on a Starflight, not the 10"s, per say.
So you bought one of Wildmans/s CMC plates? I don't see whay it wouldn't work on an Enchanter. 3.5" is pretty good for all-around use, water skiing, tubing, etc., but you'll end up going up from there soon I bet. So set it up so 3.5" down is at or about as low as it will go so you have the adjustability to go up.
