john lamon
I was just out in the garage having a beer in the mate and thought I'd check out the gauges in the dark. I haven't had this boat out at night yet but I do lots of night time cruising and I know this is going to bother me.
first of all the speedo, water pressure and fuel are turned on with the nav switch, the tach, temp and trim are turned on with the key, I would like them to all come on with the nav switch.
second problem is the speedo and water pressure are green, the fuel white, and the tach, temp and trim are red, the red one's are so dim you can't read them. I'm pretty sure the red one's are original, as you can imagine it looks like chit.
looks like I need new gauges I would prefer them all to light up green probably, I will admit I'm not much of a electrician but would assume I can get them all coming on with the nav switch easily enough?
who would sell a gauge kit that would have all of these matching, I'm not looking to blow the farm here, just some average not bad looking gauges will do.
Thanks, John
Thanks, John
