Closed cooling leak
ynnad
I added a closed cooling system to my 7.4MPI Enforcer. It cools the engine and the manifolds, and has a blocked gasket between the manifold and riser (stock exhaust, through hull). The raw water exits through the risers.
When it cools down I notice coolant (green with antifreeze) on the engine mounts, some of the plug wires and about a pint in the bilge. While it is not a lot, it concerns me that somewhere it is leaking. I thought it may be at the riser/manifold junction, so I pulled all the bolts between the risers and manifolds and re-sealed and re-torqued them, but I still get about the same amount. I never see any leak when running...
Ideas? Vinny did you ever see this on your system before you went to headers?
Thanks
Dan
No, mine has never leaked. The best thing I can tell you to do is to get an automotive radiator pressure tester and pump up your system. This will force the leak to surface.
Vinny and Eric ---Ok- sorry in advance for the long message...
Been looking for a pressure tester, but since I am from out of town, that is a slow process down here in Florida - don't have my "back home network"...
It is really a slow leak. I can flush the bilge, wipe everything dry and check back in an hour and it is ok...overnight it weeps about a cup of coolant...
I changed the riser gasket again and filed the mating surfaces flat, carefully torqued the joint.
I still see coolant drops on the bottom of the exhaust manifold runners and dripping into the bilge.
No sign of leakage anywhere above the runners. Riser joint is dry. No sign of coolant in the oil.
Coolant seems to seep out of the bottom of the runners. Can that be? They are all moist and rusty on the bottom, where the rest of the manifold is painted and dry.
Boat was repowered and has only 106 hrs on new engine...possibly they re-used old manifolds? (350 hours total on boat). Since it is a 1990 model, the manifolds could be 16 years old. Noted that the manifold drain will not get all the water out of the bottom of the runners since they are lower than that..all those years of rusting from the inside out...?
Also I noted when test running looking for leaks that the raw water discharge is not equal between the 2 exhaust banks...possible corrosion and plugging in one riser? I ran a hose into the intake of the heat exchanger and confirmed unequal discharge. But it all flows out the low flow side when I pinch off the opposite hose.
Beginning to think I will need new manifolds and risers..
How do failing exhaust manifolds start to show themselves?
Dan
Back again after pressure test. Worst fears are real.
Leaks at the bottom of several runners in rusty (feel solid but obviously porous) areas. Looks like new manifolds and risers while I am at it.
Getting a pressure tester is another story altogether... see related link in non-boat topics.
Erik and Vinny, thanks again..
Dan
At least you found it. As you found out, pressure testing is the best way. Manifolds and risers are no big deal. You certainly got your moneys worth out of the old ones. Maybe now is the perfect time to look into an aftermarket set.. It can only help.
ynnad, I may be able to help you out on manifolds. Let me know which type you have and I will get you a price. My brother replaced one on his 350mag last season and the price through my company was only around $140+shipping. If interestede, let me know and I will see if they are still available. Sorry about your misfortune
boatman
Hey ynnad, I just checked, Merc. big block center riser manifolds for $175 each plus shipping. Includes manifold and riser gasket. boatman
Better yet, Complete GLM aluminum manifold kit with riser's and all of the gaskets and hardware in stock ready to ship, $640+shipping. boatman
Boatman thanks for checking for me. I saw your post just now..
I found a local place,Marine Trading Post in North Ft Myers, that had the GML Aluminum manifolds and riser kit for a price almost the same as yours and I picked it up after church today... Took all the old stuff off before the Daytona Race started and will install the new parts tomorrow! I can hardly wait to get the Enforcer back on the water!!
Dan
Glad you found your leak, sorry about what you found though. I was going to suggest you also check your ex manifold bolts... Not sure about the big blocks, but it is not that uncommon for a small block exhaust manifold bolt to tap into the water jacket, and if not sealed with a sealant they will sometimes seep coolant. This is especially true if they have ever been repaired (i.e. retapped or heli-coiled).
