fbpd227
Ok, I'm sure those of you who have been following my SLOOOOW buildup are chomping at the bit to see how if I have the combination right yet or not......well...... keep chompin! LOL
The set-up:
24p Stainless Precision Turbo prop
10" set back/ jack plate- set on the middle motor bolts to the jack plate, lowest holes on the plate to transom ( approx. 3" below the pad )
200HP 2.4 carb motor- unknown gear ratio on the older lower unit?
Myself, wife and gear, with a full tank of gas ( heavy load of tools as well )
Lake and conditions:
Lake Hartwell, SC
Light chop
rain at times
The results:
50-52 GPS trimmed up till just before losing water presure
54-5500 rpms
20-24 psi water
52 speedo
BAD PROP HUB!!!!!!
bastage first started "blowing-out" on hard take off's...then once or twice after running hard and pulling back on the throtle and stabbin it again it blew out until I finally realized the hub was lettin go and backed way off. After partying on an island for a few hours I went to leave and tucked the motor all the way in ( also tightned the prop nut a bit more to make sure I got all I could get from it ) and feathered it up till on plane, then trimmed her out and again hit the throtle - same performance- 50-52 GPS speed- So I believe I need to find another prop while I get this one rehubbed. I have NO idea of lower gear ratio- seems to me like this setup should be ALOT faster!?!?!?! So for those of you that have been following my "adventure" and offered advice and asked for more info to help me figure out what to do next- I HOPE YOU FIND THIS POST AGAIN!!! LOL! Seriously I KNOW theres "issues" to work on now- just trying to find out my lower gear ratio, and next step. I want to try to find a 25 ( maybe a 26 ) pitch prop to try/ test- then a 22- 23 to try and test...to give me a few more base lines- then I need to find out WHAT TYPES of props work best on the Enchanter hulls. Alot of questions- I know- but I tried to give as much info as I could to help those who are helping me tune er in....
One other thing- I can almost trim my motor all the way up before I lose water pressure- does that mean I can raise the engine to the bottom holes on the motor to jack plate bolts ( @1- 1.5 inches or so ), and/ or raise up the last 3/4- 1" of adjustment on the jack plate as well- Whats a typical x dimention with a 10" setback? I thought 3" below the pad was "dicey" to start- but I have tons of presure- and I'm NOT even running scoops?!?!?
THANX GUYS!!!!! ALL OF YOU!!!!!!!!!!!!!
The set-up:
Lake Hartwell, SC
Light chop
rain at times
The results:
54-5500 rpms
20-24 psi water
52 speedo
BAD PROP HUB!!!!!!
