Vandalizer
I have a ____hp crossflow V4, and the two times I've had it out, I haven't yet mastered cold starting. Once the engine is warm she starts right up, but cold starting is a real bitch.
Any suggestions on which combination of choke, throttle, cranking, process, etc I should try?
So far I've alternated between using the choke and not using the choke while cranking, and applying 1/4 ish throttle after I begin cranking.
Also probably important to note that I don't have a primer bulb, but do have a fuel pump inline.
