I'll try to make this short. the cam must make power to high maybe. Should i try to advance the cam to drop the power band 500 rpm or so lower in the rpm's
The 350 engine wont power past 4300 rpm with a 14.25 x 21 mich wheel SS prop. Its in a boat that's 21ft i would guess is around 3000 dry. 3300-3400lbs with me and gas. My fuel pressure is 6psi and timing is 9* with a advance of 21* total of 30* , i cant tell if the advance works but it should do so around 2600-3000 rpm. 93 gas also. Here are the parts on the engine.
stock 4 bolt main truck block
Pro Action Redtopline Heads 180cc x 64cc
Comp Cam Beehive Springs Good For 550 Lift
Ferrea Valves 1.94 Intake / 1.50 Exhaust
billet msd dist and box
Weiand Stealth Intake Manifold & 600 carb
Comp Cams 12-244-4 "Xtreme Marine" Hydraulic Flat Tappet Camshaft & Lifter Kit
Fits 265-400 cu.in. small block Chevrolet V8s
Comp Cams "Xtreme Marine" camshaft is the latest series of hydraulic cams to take advantage of the newest development of camshaft design and valve train technology. It has an aggressive lobe design that produces better throttle response than other cams with the same duration and they still deliver strong engine vacuum. "Xtreme Marine" cams can be used for any high performance application where both low to mid-range torque and good throttle response are desired.
RPM Range: 2,000 to 6,200 rpm
Duration @ .050" lift: 234/244 (int/exh)
Valve lift: .498/.500 (int/exh)
Good for jet boat with A or B impeller, good off shore high performance cam, rough idle.
Comp Cams 12-244-4
• Aggressive lobe design
• Excellent throttle response
• Strong vacuum
• Excellent in high performance applications
• Good low to mid-range torque
should i advance the cam and prop down to a 17-19 maybe to get in the higher power level of this engine
