The high speed wiggle. I know it well.
First do you have a jackplate installed?
Do you have a chne problem or is it a wiggle that starts in the stern and gets worse untill you call no joy and slow down.
If its a wiggle. Things to check would be steering, any play? If so it needs to be removed, Motor mounts. Check for play there. The factory mounts are incased in rubber. I installed soild upper mounts in mine.
Check the prop, bent or damaged blades will give ya fits.
also not sure about the prop you are running. The laser 2 seems to be the prop of choise for the smaller OB mate's they provide great bow lift.
If its chine, This is when the boat is having trouble staying on the pad. Side to side motion.
Check the weight balance from side to side. With practic this can be driven through.
A jackplate would help a bunch, also a plate with setback. Checkmate's are know to be real bow heavy. You said you where rock steady untill you have to trim up to get the last few MPH. You are using the engine to help carry the bow.
I would say install a jackplate with 8-10" of set back, a water pressure gage, and raise the motor up.
On my tri-mate with the engine all the way down my "wiggle" is to bad to drive. I rasied the motor up 4.5" and the wiggle is gone. This was a hyd plate with no set back. This winter I am installing a plate with 5" setback and I will be able to raise the motor even higher. I may have to installe a low water pick-up, but that will have to wait untill next year.
Good luck and keep us posted.
What Rpm are you turning.
Also would love to see a picture.
[This message was edited by 175checkmate on December 05, 2002 at 01:38 PM.]
