Gimme Fuel
I have the Boat Leveler Co. "Insta Trim" dual cylinder trim tabs on my 253 and the hydraulic hoses are shot. I need to run all new lines to them which means fishing them through the hull. I have a couple questions:
-Can I use any common hydraulic hose or do I need the Irridium banded $3.36/ft hose Insta Trim sells?
-How much pressure can I put on the plastic nipples on the cylinders to remove the hose locking collars before they snap off? Seems chinsy to me having a plastic nipple/slip collar like that. I tried to slide it up with a little force but Im scared of breaking it. Any special tricks here?
-What fluid can I refill system with? Common ATF? It has all leaked into my bilge a while back.....
-Any special bleeding procedure?
Thanks for the help guys. I am going to remove the hoses, paint the bilge, then reinstall everything.
