'91 Starliner
I was curious if it would be ok to trailer motor in vertical position with the cmc hydrolic jack plate raised up all the way? I ask this question because it seems to me that it would put less stress on the transome. Picture the motor in running position not trailering, jack plate raised all the way, sceg plate is 3-4 inches above the bottom of low spot in trailer. By trailering this way the weight is closer to the transome as oppossed to motor kicked out, I don't know if this makes much difference. Also I didn't know if trailering with jack up would put undo stress on hydro-cylinders? let me know if anyone does this or if bad idea! Thanks in advance
