Hi all,
First of all, I am not a very experienced boater, and I am sure some of my questions will reflect that
A while back I got an '82 Eluder. It has the 470 Mercruiser (3.7l 4cyl) I/O.
It has a 23p Cleaver prop on it. From everything I have read on this forum and elswhere, this is the wrong prop for this boat. These boats need a bow lifting prop and the cleaver is a stern lifting prop.
I have been working on it (replaced the floor, new starter, etc.) and finally got the boat on the water today.
It was doing 58mph (according to the paddle wheel wired to my fish-finder) at 4400 RPM. Cruising @ 3000 rpm registered 36 mph.
I doubt the speed is accurate, but the RPMS are perfect, as the motor is supposed to be run between 3800 and 4400 @ WOT.
AS expected, I don't get much bow lift. I can't plane below 25mph. It gets up on plane fairly decent...a little slow maybe.
I would like to switch to a more appropriate prop, even though the performance of this cleaver is not too bad.
Is there a difference in the effect of a given pitch between a cleaver and a more conventional prop?
In other words, if this cleaver prop is the perfect pitch @ 23, should I stick with a 23 in a conventional prop, or should I go up or down in pitch?
Should I even change props? Is not planing below 25mph normal?
I was thinking of a Hustler prop because it's cheap and I can see if I get much better results.
regulations to prevent fire, etc. i dont know the differences but heard - distributor, starter, carb, etc must be marine to be safe.
