My '74 merc 1150 will not reverse. Forward works just fine, although when it engages it does 'bump' a little. When moving into reverse, it sounds like a couple bearings rattling around inside a coffee can. When I am on land and have the water wings on, the prop DOES move in a reverse direction. When in the water, it isn't enough to propel the boat. I didn't find any metal in the fluid when I drained the lower unit. I figured if something was stripped it would affect forward also. Any suggestions (other than getting a newer motor)
