That's pretty much the same slip I have with a 23 Tempest Plus. You have lot more setback than I, but I use lots of positive trim which increases the slip.
At lower speeds, trim the slip is much less.
Don't know if this helps, I just don't think these hulls are going to be much lower than 10 percent.
11% slip is not that bad.
Robby
I think those a good slip numbers. The bigger the boat, the higher the slip. You got too used to that 16 footer! If you every have a chance to try a Renegade go for it. They are a great prop and will make that hull behave much better.
Hey Robbie!
Mind if I tag along and try some of those props you got there? Im just trying to learn what prop my boat is gonna respond to, IM hoping to get my tach resolved tonight, found a bad rectifier, just picked one up, so my project tonight is putting it in....planning to be on the water tomorrow and sunday, but not sure as to what water, intercoastal, lake, etc...
