Jetmate
Thanks guys,
I appreciate all the help and info. I have the engine out now and apart. Found the number 6 piston had thrown it's rod. Have freind that is coming by to look at it for me, he works at a machine shop and rebores/rebuilds engines and is part owner of the local dragstrip here. I know the crank is going to have to be turned and bearings replaced. The problem is all of the mechanics here work on car engines not marine engines. As for the Camshaft, how can you tell what size/RPMs it is, I was told that I needed a cam with rpms up to 5800 (I think). If it hasn't been bored, I'm going to have it bored and I would like to have a little bit of a lope in it, when it goes back together. A little more HP would be nice. It does have a Holley 600 and a Edelbrock Torker 455 intake, but as for the HP now I have no idea, because I don't know if it has been previously rebuilt. What about a gasket set, can I use a regular type gasket set or does ot have to be a special type set? Friend is suppose to come by and look at it tomorrow or Tuesday.
Again, Thanks for everybodys help, I appreciate it.
First thing get a roller cam, lifters, and rockers. It's worth it!!! If the guys doing the rebuild work on enough engines they should be able to guide you to the right cam. You are going to need something with a mid range power band. If you like I can look up the specs on the cam they put in my .30 over 396. It worked out great for me. Sounds great, nice lope, not to radical. Let me know. You can then ask them what they think or maybe get close, spec-wise.
on them. As for the roller cam, lifters, mine has hydraulic lifters in it now, was going to replace them with new hydraulic lifters
. Hope to finds out something tomorrow afternoon.
