Needafunboat
Hi Guys,
Anyone know the differences between these two props. I know that the Rev. 4 was originally designed for OB's, but ended up also working well on sterndrives. I've also heard that they provide good sternlift - which would probably be good to help pull my rear heavy BBC rig up out of the water. Searching some other forums showed the general trend of 4 blades improving handling, mid range and hole shot, reducing top end slightly. Also seem to be better suited to well/over powered boats - no real surprises with that info.
I saw some interesting slip numbers from a few different sources - the Rev. 4 had very low slip at lower and cruise speeds but it seemed to be even with a 3 blade at top speeds. I wouldn't have expected a 4 blade to be more efficient at cruise - maybe getting the boat up out of the water helps there.
Anyone info about the Bravo's or Rev 4's would be appreciated!
Thanks!
Thanks!
