Jimway
The small band of outlaws goes to work on the roadster as soon as they return to camp. Close inspection of the valve covers reveals that , for some reason, the lip of the valve cover that was bent down around the outer parameter of the cover to help hold the gasket in place, has been ground off. Another set of valve covers are going to be needed. Four of them. The cars owner and driver argue, fuss, and fume over the rear axle ratio. The cars owner thinks that he has a set of 2.3 gears for the 9 inch Ford rear axle that is under the roadster. The driver wants to lower the engine rpm to keep from blowing it up, but feels that there may be more 'speed in her'. All present are concerned about pressure buildup within the big motor at speed. A restart of the engine reveals no problems as it roars to life under a pop up canopy shade. Everyone is relieved as the motor fires back up and idles at about 1000 rpm with the blower whining even at idle. The whole car leans over noticably as the throttle is blipped, impressive. The car will be back soon to this spot on the side of the road. Proper valve covers will be on it and it will also be sporting a 2.33 rear axle ratio. The men work with a special comradery. They take pride in thier job and equipment, and in being part of a special team. The respect that they have for each other is remakable and friendships have developed. Disagreements occur from time to time. Loud voices and the occasional thrown tool indicate human nature, but altercations are soon forgotten as its back to business.
