scottcleaver
I need help with an alarm gremlin. in the shifter throttle area underneath is a small alarm fed by a purple wire and a beige wire with lt blue stripe. The alarm is going off when the engine is running. I need help in diagnosing. I have no engine codes. The water temp, oil pressure and charging systems are all perfect. I changed the outdrive oil resevoir as I thought it might be the problem because it sets the alarm off if the fluid gets low and I thought the sensor might have been bad.Any ideas would be great.
1999 ZT280 with 502 Mag
Thanks
Scott
Thanks
Scott
