Brian
Hey guys I have a tech. ? for ya'll. Heres the deal, Did some work to the Rude on the boat need more prop so I got a bigger prop. The prop I have is still not enough but I am going to run it easy for the beginning of the season, so my ? is how high can I run the bullet of my nose cone from the bottom of the boat, it seems that the higher Up on the jack plate I go the worse the chine walk gets but the speed gets higher. I am running a 29 omc SRX prop which is not worked "YET" I can turn it until I hit the Rev limiter, 6250.Is there a point were the boat will not resond after I get so high on the jack plate, because I can keep rasing it but the higher I seem to go the worse the handling gets, I would like to hit 85mph with it 82.7gps right now, any info would be a help thanks.
Brian
Brian
