I agree, my 350 with wet thru hull's is not all that loud.Really i don't think the 350 is all that offensively loud with standard thru-hull exhuast. Yes the water coming thru does make a difference and you do get a nice throaty V-8 sound.
So are you saying that if I do run it throug say a pair of 4" diameter emi mufflers and a couple of elbows between the risers and tips it would probably be fairly quiet? That's actually what I'm hoping to accomplish... (sorry to hijack the thread)
I would not bother with the mufflers its only a small block 350. I would try it without the mufflers first. If its 2 loud for you, then buy the mufflers. The mufflers are pretty expensive. Its very rare around here to see mufflers on anything unless its dry exhaust.
Even my jetboat isn't as loud as it looks with water injection. But if you are that worried about sound leave it alone. Why bother with thru hull exhaust on a 350 if you are going to quiet it down so much it will sound like a new 4cyl running. If you want the look just bolt 2 exhaust tips on the back.
LOVE the jetboat! has got to be a blast to run!
Your point is well taken, but even if the risers weren't going to be too long to run the Y-pipe, it's too restrictive. I'm replacing a v-6 with a 383 and will be running IMCO Power Flow manifolds and risers. Hopefully even with mufflers it won't sound like a 4 cylinder...
Independent of how it winds up running, it's starting to look good... Thanks everyone for the thoughts...
