81Diplomat
I noticed some oil in the aft hull. The tilt/trim pump was oily so I cleaned it and tightened a couple lines that appeared to be leaking. The pump was sitting is this area on the bottom beside gas tank.
I pulled it up to the rear seat for easier inspection and maintenance. I waited overnight and appeared to have fixed the leak. I put in back in the bottom of the hull and an hour later noticed more oil. It may have been leaking from the fill screw, but can't confirm that yet. I cleaned that area again to verify in a couple hours. Since this thing is just sitting in the hull not secured to anything, I started to wonder if it should be mounted in a certain position to avoid leaking. What say you CM gurus?
